LT80 Carb Question
Old Nov 15, 2011 | 08:04 PM
trvandrew's Avatar
Default LT80 Carb Question
Hi any who look at this im new owner of a 99 lt 80 and new to forum been looking on here a bit and seems to be very helpful people.
I am thinking of buying the boysen reeds and wanted to know when i remove the carb and reed cage i am assuming any gasket or o-ring will be shot. Can someone tell me what gaskets,0-rings or both ill need for replacement once i install new reeds and reassemble. Thank you
Old Nov 16, 2011 | 05:57 PM
LT80's Avatar
LT80 Expert
Welcome to the forums.
There is a o ring that goes in the insulator (black plastic thing). It is re-used.
I use a lil grease to hold it in place during installation.
The reed cage has a o ring but it's made into the cage itself. It cannot fall out/etc.
The reed cage screws are phillips head and can be tough to get out. I use a ratchet and special thingie to make it a phillips head (#3 phillips). Some use vise grips.
I replace those with hex head bolts (6mmx100x16)
Old Nov 16, 2011 | 06:09 PM
trvandrew's Avatar
THx alot Lt 80. I see what u mean on the reed cage bolts i tried everything and can not get them. Think i would have to pull the motor to get them and figure if i have to do that the reeds are good enough lol. Thx alot for the info and i seen on another thread that u use a different chain and sprockets for yours that works well could u elaborate on your chain and sprocket set up plz THx LT80
Jmuddin284
Jan 19, 2026 07:16 AM
tweeder
Jul 5, 2015 01:57 PM
yambam13
Jul 4, 2015 01:49 PM
Mikea1978
Jul 4, 2015 12:37 PM
D-Hagz
Jul 4, 2015 02:19 AM
