Eiger 4 wheel drive problem
Old Dec 5, 2011 | 06:34 AM
bobby d's Avatar
Smile Eiger 4 wheel drive problem
I have a 2006 suzuki eiger that will not go into 4 wheel drive. I am a new member of this group and will appreciate any help .
Old Dec 5, 2011 | 07:40 PM
beart0y's Avatar
Your cable is too tight to allow the dog to engage.
Cable jammed.
Old Dec 6, 2011 | 06:53 AM
bobby d's Avatar
It used to be ok, I heard a clunk the other day and now there is no resistance when i move the shift lever from 2 to 4 wheel drive
Old Dec 7, 2011 | 05:45 AM
Scott267839's Avatar
If the cable is broke then it should be in 4X4. Are you sure it is not in 4X4 all the time?
Old Dec 7, 2011 | 09:39 AM
Back40's Avatar
Disassemble the 2wd/4wd shifter and see if the cable end has broken loose from the plastic end. If so, you will need to replace in order to switch to 2wd. The new ones are all metal.
Stillonit
Jun 18, 2015 11:23 AM
volsgo30
Jun 4, 2015 06:07 PM
Steven Bandemer
May 27, 2015 07:39 PM
CanadianViking
Feb 16, 2001 11:56 AM
caldwell
Oct 28, 1999 03:30 PM
