03 eiger 400 4x4 carb issues
Old Mar 27, 2012 | 09:21 PM
Mike Wilhite's Avatar
Cool 03 eiger 400 4x4 carb issues
I think i figured it out just doin somemore checkin added a k&n filter and snorkle idles great touch the gas and falls on its face unless u cover part of the intake tube guessing i need to get bigger jets now im thinkin i added to much air. Any ideas throw them at me thanks
Old Mar 28, 2012 | 01:39 AM
treveiger's Avatar
One of your jets(pilot I think) could be clogged. Mine did the same thing an that's what the problem was. When you take apart the carb clean it out also. These Quads run lean from the factory so i wouldn't be afraid to bump it up. Sense yours seems pretty lean I'd try a 132 main jet so see how it runs then an start from there.
Old Mar 28, 2012 | 06:08 AM
Yup i cleaned the carb out before i posted pulled some crap out and added a inline filter due to no strainer on petcock with no filter i found it runs great with a rag over the intake tube
Old Mar 29, 2012 | 04:02 PM
treveiger's Avatar
Ok I'd definitely put a bigger main jet in it would be my first choice. Also make sure no hoses on the carb are not pinched or anything too.
Old Mar 29, 2012 | 05:26 PM
Yup im thinkin the same just took it out lastnight with a towel over intake tube did perfecr all night 1 backfire but thinkin my fault to high of rpm in the mud
Old Mar 31, 2012 | 12:53 PM
treveiger's Avatar
A bigger main jet should fix the high rpm throttle let off backfire, it did for me an i wind that thing up pretty good.
Old Mar 31, 2012 | 04:35 PM
Thanks boss man any ideas where to get one im findin mostly stock jets
Old Apr 5, 2012 | 10:38 AM
treveiger's Avatar
Any cycle shop should have them. I went to Suzuki an they didn't have the right ones so I headed to Performance Cycle an they had them there. Make sure you get the right type of jet, they shouldn't look like a long nut, it should be round short and a split for a regular screw driver. Sorry for the laggy response, been busy lately an it ant slowing down. You'll have to let us know how it goes.
Old Apr 5, 2012 | 10:50 AM
Yup ill let u know it might b a few weeks depending on price thanks for the info
Old Apr 5, 2012 | 11:03 AM
treveiger's Avatar
My local cycle shop sold them for $4.50 a jet which isn't bad. What elevation do you ride? We might be able to give you a guess on where to start on jet size, or if you go to a place where people know what your talkin about they should be able to help you also.
Jmuddin284
Jan 19, 2026 07:16 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
tweeder
Jul 5, 2015 01:57 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
Mikea1978
Jul 4, 2015 12:37 PM
