1999 250 quadrunner carb settings
Old Aug 19, 2012 | 02:03 PM
Jmuddin284's Avatar
Default 1999 250 quadrunner carb settings
I just picked up a 99 quadrunner 250 2wd and the carb is off and completely apart. The guy took it to a shop and they told it the bike needed new front brakes and the carb rebuilt for $550. I know I can do all the work, but I need to know what the mixture screw setting is as far as the baseline or what it should be at stock. And the float setting too, I know on both my polaris bikes the float setting is upside down level with the bowl mounting surface. Will it be the same on this bike too? Thanks in advance!
Old Aug 21, 2012 | 10:23 PM
Jmuddin284's Avatar
well I guess nobody has a (somewhere around)1999 quadrunner and has EVER had to work on it.... the bike is supposed to run like a champ but the carb needs rebuilt and is already taken apart.... all I need is a starting point for the settings but I guess the zuki guys aren't as friendly or as helpful as the POLARIS folks... too bad..... I guess I'll buy a manual for it and not give info like the rest of you guys.....
Old Aug 27, 2012 | 08:32 PM
Jmuddin284's Avatar
wow.... I can't believe it.... it's been a week and 91 folks have viewed this thread and still.... still haven't seen any response to this question.... I tell ya'll what, The factory setting of the mixture screw is 2 1/4 turns out from lightly seated.... Thanks everybody....
Old Sep 14, 2020 | 09:58 PM
Sarah Koontz's Avatar
do you happen to know the measurements for the float? We’re having carb issues as well and can’t find crap about the float settings
Old Sep 15, 2020 | 01:25 AM
Jmuddin284's Avatar
Sorry bud, I got rid of that machine a year or so ago and gave the new owner the manual. If I had to make a guess, I'd say make the float level when upside down unless they're the round floats(I cant remember which ones it had) then the tang would be level when upside down. I hope this helps🤞
PapaWheelie
Sep 15, 2011 08:37 AM
ds4life
CAN-AM (BRP) Ask an Expert!
May 9, 2010 08:25 PM
79hugger
Oct 27, 2008 10:38 AM
lepper
Sep 24, 2005 10:27 PM
Jack110
ATC 3-Wheelers
Jun 21, 2004 11:56 AM
