Wont Rev up
Old Dec 10, 2012 | 05:38 AM
Qaudfussion's Avatar
Default Wont Rev up
I have taken the carb off, cleaned it, replaced diaphram and float bowl assy. but I can not get it to rev.. and it wont idle smooth. Nearly forgot, I also replace the coil, wire and plug.... Has anyone else seen this problem before? Im at a loss !
Old Dec 10, 2012 | 06:51 PM
papa hogg scoot's Avatar
Loved
Community Favorite
What atv are we talking about.....Thanks
Old Dec 10, 2012 | 06:53 PM
04 arctic cat 400 that has the suzuki eiger motor
4x4 auto
Old Dec 10, 2012 | 07:01 PM
Loved
Community Favorite
Pinch off the fuel line with an pair of needle nose pliers an listen to the engine while hold pliers and engine throttled up...when engine stars running out of fuel see if it runs and revs good before it engine quits...If engines run fine then you have an fuel promblem if run the same prolly ignition problem...Than get back us here an we will go for there..Good luck
Old Dec 10, 2012 | 07:06 PM
Thanks, I will go give it a shot!
Old Dec 10, 2012 | 07:09 PM
Loved
Community Favorite
I have had bad recfiter\reg go bad an causes alot of ilde and no rev problems...Had an 300 the other day that had an brake switch enaged an wouldnt rev up...
Old Dec 10, 2012 | 07:13 PM
Loved
Community Favorite
Sounds like atv may not be charging..Put an volt meter on battery before start up check batt volts needs to be 12.3 to 12.6 before start up..then crank up rev engine..should be 13.3 to 14.2 are so then regulate not keep climbing higher an peek out all ignitions parts...Also check this an get back with us here..Good Luck
Old Dec 10, 2012 | 07:15 PM
Good call, I did just what you told me to and sure enough , as it was running out of gas, it reved up and smothed out and when I took the pliers off the line, it went back to very bad idle and no rev.
Old Dec 10, 2012 | 07:30 PM
I dont know what in the fuel system could be causing this after all I have done to the carb....could it be the jets and should I pull them out and clean them to see if that solves it? I really do appriciate all your advice.
Loved
Community Favorite
Great...Sonds like prolly needs an repair kit put in it...with new hardware..Prolly got worn parts inside of carb from having an bad air filter sometime down the road an sand blasted brass parts an cause an rich mixture..
