2004 Eiger Front Axle.
Old Jan 21, 2013 | 11:39 AM
hooknhunter's Avatar
Default 2004 Eiger Front Axle.
Hey all,
I'm new here. Hopefully you can help me out.
I was using my ATV the other day and the 4WD quit working. While looking into the problem, I discovered that one of the front axles is pulled out of the differential about 1 to 1.5 inches. It was using it in snow and none of the oil appears to have come out of the differential. From what I can see from the parts manuals I've been able to look at, it appears that I might be okay if I just shove the axle back in. Does that make sense?
Hope to hear from someone who can help me out.
Old Jan 21, 2013 | 02:29 PM
TLC's Avatar
TLC
Should just shove back in ,only a snap ring holds it in place,at worst you may need to buy a new snap ring and clean and lube the spline of the axle and the hole it slips into of the front diff.
Old Jan 21, 2013 | 04:16 PM
Thanks for the reply. Can that be done without any disassembly or am I going to have to unhook the axle, etc from the suspension to do it.
So far it looks really clean. So I'm thinking I won't need to clean/grease.
Old Jan 21, 2013 | 05:25 PM
TLC's Avatar
TLC
There are many vids on you tube, here one of many.
Only thing is you will be shoving it in ,not pulling it out. Does not matter about which ATV it is there all the same when removing/installing a axle.
You have to take it apart to see why the axle slip out in the first place. Also to clean up the spline and check the snap rings condition.
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
baysport
Jul 23, 2015 11:37 AM
Gtsordo
Jul 13, 2015 10:38 PM
jettman
Jul 6, 2015 12:16 PM
