Quadmaster 500 backfiring after jet kit. Any advice?
Hi. I recently had to replace the diaphragm on my QM 500, so I decided to add a sigma 6 jet kit. I basically replaces the main jet with a 135 (was 130) and moved the clip on the needle down one space (as per their directions) towards the RICH direction. Now that I have it reinstalled it starts great, idles great but if you try and give it any throttle it sputters, pops and looses all power. With the choke on it will accept throttle.
This implies to me that I am running LEAN, which seems strange as I moved the needle towards rich and put a bigger jet in?
I have checked the rubber connections on either side of the carb, the carb has been out and it is CLEAN.
So any thoughts other then just "clean the carb".
Thanks
Chris
Thanks
Chris
jrooker6
04-23-2016 07:36 PM
