1996 King Quad 12V outlet
Old Apr 12, 2015 | 12:20 PM
KQUAD's Avatar
Default 1996 King Quad 12V outlet
I am doing some wiring on my quad and plan to install a 12V outlet.
Any reason it won't work on the side of the front fender beside the steering column?
Since I don't have many posts I'm not sure I'm allowed to post pictures yet, or if I am, I'm not sure how to do it from my computer which would clarify it better.
Thanks
KQ
Old Apr 12, 2015 | 09:31 PM
Before all the dc outlets were installed in the head light pods,a lot of people installed them on fenders,front panels,etc on Polaris machines. Choice is yours as to a mounting point. I'd just find a wire that's only on with the key switch,splice into it.You possibly may have an unused accessory wire,then tie the ground wire to a common grounding wire point or to the frame.
Old Apr 12, 2015 | 11:00 PM
KQUAD's Avatar
Thoughts on a max amp rating for a fuse in this type setup? I'm not going to think the factory ACC wire would be fused.
10 amp be enough?
Old Apr 13, 2015 | 11:49 AM
Most cases a 10 amp fuse for the accessory outlet is good enough. Wouldn't go any larger as you'd want the fuse to blow rather than having the wiring melt or an electrical fire. Large draw spot lights could be a problem,but normal accessories should be ok.
Old Apr 13, 2015 | 12:43 PM
greg74's Avatar
The only thing I've ever used for my 12V outlet on my Rancher is a tire inflator. But its nice to have it. Its located on the left front fender which is probably a common location for most of them.
GregM
Mar 6, 2018 06:53 AM
GregM
Jul 29, 2015 09:41 PM
Countrygirl1976
Ask the Editor
Jul 13, 2015 12:19 AM
DOC HOLIDAY
Jul 9, 2015 01:09 PM
D-Hagz
Jul 4, 2015 02:19 AM
