84 LT50 A little help please ?
Old Jun 15, 2016 | 05:05 PM
Jeep Maine-iac's Avatar
Okay......my top end is on its way in the mail. Planning on tackling this over the weekend and hopefully it'll be screaming around for my 8 yr old son by monday.
So...... I'm looking for some assembly specs. Ring gap ? And cylinder/head stud bolt torque ? LT80, you mentioned that you have or have access to the microfiche manual. Can you help me out please ? Anyone
Old Jun 15, 2016 | 05:10 PM
Top end kit is on its way. Need to know some assembly specs. Piston ring gap ? And cylinder/head stud bolt torque ? Can anyone help me out here ? LT80 you mentioned having or having access to the microfiche manual.
Hoping to tackle this over the weekend and have it screaming around for my 8 yr old son by Monday. Thanks for all the help everyone !
Old Jun 15, 2016 | 05:39 PM
LT80's Avatar
LT80 Expert
I go to a suzuki dealer website and use their parts fiche.
90/100 inch pounds on the head nuts.
Gap: as long as there is a gap it'll be fine.
What brand parts are coming?
ummm.....LT50 screaming??? LOL
Old Jun 15, 2016 | 08:26 PM
Well if you thought that was funny you're gonna really laugh at me now ! LOL
Purchased on Amazon.com
From "TOP NOTCH PARTS"
It was cheap, free shipping, and it looked better than a lot of other cheap parts I found.
I figure it's good enough for the kids right ? Hahaha
Old Jun 16, 2016 | 07:03 AM
  #15
LT80's Avatar
LT80 Expert
Should work fine.
Old Jun 20, 2016 | 01:30 PM
  #16
DirtDevil101's Avatar
No reeds...haven't seen that for awhile...sounds like a good'o piston port...had a number of Polaris sleds that were piston port...
Old Jun 29, 2016 | 09:36 AM
  #17
JEEP-Maine-iac's Avatar
Originally Posted by LT80
Should work fine.
Okay......new top end, and it's running great. Just 1 little issue I would like some advice on. If im not mistaken, and im understanding it correctly, then this thing has a really weird petcock. No " off" position. The "prime" position which is horizontal left or right, gravity feeds fuel to the carb for cold starting. The "on/open" position which is vertical, uses a vacuum operated diaphragm pump within the petcock.
So here is my issue.......the factory cylinder I removed had a hose barb on the cylinder right next to where the inlet tube connects. The OEM replacement didn't.
I am thinking I would rather drill, tap, and insert fitting on the inlet tube itself rather than the cylinder. It would be easier, and it would be cheaper to fix if I mess it up.
Any reason this won't work or that I shouldn't do it ?
Any input anyone has is greatly appreciated
Old Jun 30, 2016 | 01:44 AM
  #18
I can't see any problem with fitting the vac tube on the inlet manifold pipe. Most bigger Suzukis have the fitting there anyway.
elgibbsdee
Aug 27, 2000 05:34 PM
littleatvr
May 18, 2000 07:45 PM
littleatvr
Apr 28, 2000 02:36 AM
chrisjack
Aug 21, 1999 04:52 PM
MXrider
Aug 2, 1999 01:46 PM
