2004 400 eiger
Old Apr 24, 2017 | 09:33 AM
suzukiboy##'s Avatar
Default 2004 400 eiger
will not start when choked but will with no choke, dies when throttle opened, it ran poorly last time running then came out of it. The flywheel / magnets were bad and replaced, the carb was cleaned with new needle and seat, and I do use non-oxy premium fuel. Also had fuel petcock replaced any ideas as to the problem ?
Old Apr 24, 2017 | 03:03 PM
Bulldogs's Avatar
Check to see if the spark plug is firing good. Also I replaced my petcock & added a fuel cut-off valve- due to gas getting in the oil.
Old Apr 26, 2017 | 11:00 PM
johnkaleb's Avatar
try firing it up then placing your hand/rag/etc over the air filter hole restricting the air flow and see if it'll rev up, if it does you're getting too much air.
Old May 2, 2017 | 07:07 AM
oldhoss's Avatar
mine acted that way, would start and idle perfect but as soon as i gave it gas it would bog and die. mine had a plugged carburetor vent hose that goes under the seat.
Bulldogs
Apr 23, 2017 09:34 PM
Bulldogs
Apr 23, 2017 01:58 PM
norcaleiger
Jan 11, 2012 12:37 AM
Johnny_Foote
Aug 9, 2010 08:24 AM
Beav33
Oct 11, 2005 12:23 AM
