LT125 piston ring oem install problem/help
Old Mar 27, 2018 | 05:00 PM
thanasi's Avatar
Default LT125 piston ring oem install problem/help
Hi guys i finally got all my parts in for my LT125, replaced reverse idler and driven all assembled now working on top end refresh. Got to installing my rings today and im not 100% on which ones ore 1 and second.
As per my shop manual it states oil rings no direction no problem.
Apparently top ring is chromed , second ring is darker black and both should have a stamping R for top side. My dilemma is my rings i took off are stamped R1 and R2 ok makes sense, my replacement rings from suzuki only has one of the rings stamped R, it seems to be the darker one so id guess its second ring, the other ring has a chrome edge so should be top ring but has no R or any sort of stamping. I have checked under magnifying glass and has a bevel on both side and looks almost if not identical ??
Any one has run into a problem like this i have searched for info on line but found none thanks for any help
Tom
Old Mar 28, 2018 | 02:53 AM
If you bought the rings from a Suzuki dealer, their mechanics will have come across this, so contact them and ask if you can talk to their mechanic. Some are awkward and like to keep secrets, but most are only too happy to pass on what they know.
Old Mar 28, 2018 | 01:58 PM
thanasi's Avatar
Thanks merryman lol im a tech and i have my moments lol i wont lie BUT if approached with all info and respectful im all for helping !
Well suuzuki dealer near me is non existent any more they all closed down years ago unfortunately. I got them from a online reputable parts chain i sent them a email and waiting to hear back sucks, might make some phone calls and hope for the best while i wait for reply.
Thanks for your time
Tom
Old Mar 28, 2018 | 07:20 PM
thanasi's Avatar
spoke today with a small engine/bike/sled shop and said no stamping on ring means any side is ok. He was real confident on that, kinda makes sense tho and it does look the same has a bevel edge on both sides.
I will find out by this weekend !
dragracer789
May 19, 2004 05:31 PM
wildchild660R
Sep 24, 2003 12:06 PM
DuneMe
May 21, 2003 07:23 PM
ugly
May 19, 2001 01:25 PM
Skunky
Jul 8, 2000 01:57 PM
