99 lt80
OK compression is good
what do you suggest I look at that could be causing it to loose power and puttering out when I give it full throttle ......
It will run hard for a min but then I let off the gas and it dies down to a shut off unless I catch it in time and sometimes am able to tap the throttle a few good times to keep it alive if that makes sense......
One other thing when I flip the petcock to reserve it dies out as well....
Any thoughts........🤔
I'll check the pipe but I don't think it is that
it smokes good with pressure and still spits a bit of oil .
I've opened the little screw on the pipe and very little flow of oil comes out but not an excessive amount.
NovaKaw650
Nov 26, 2003 12:25 PM
