07 King Quad 700 sputter and stall
Old Jan 22, 2019 | 09:19 PM
AndrewPike's Avatar
Default 07 King Quad 700 sputter and stall
So this sputter and hard start has been an issue for me now for a while. Originally I cleaned the injector, set tps, checked all connectors, did the voltage reg mod, and it helped a bit. So I decided to change the fuel pump and filter, I bought a cheap aftermarket one. Pressure was 65 psi static, with just the key on and 90 psi at idle. So I modified the regulator o ring and got it now to 44 psi with key on, but it’s 60psi at idle. It will now start every time but it takes some feathering of the throttle, and when your driving, it sputters bad at low throttle and will stall. I really need some help, I researched the crap out of this, oh and it has a new plug. Only 4000km onthr bike too.
Old Jan 23, 2019 | 03:31 AM
There is something seriously wrong with a pump producing that sort of pressure, what was the original pump giving? Are you getting the C--- fuel settings correct on idle? I did have a 700KQ that wouldn't run right from new, finally swapped all the EFI bits from another bike, one at a time, until I found it ran right with the other bike's throttle body. So fitted a new TPS and that seemed to cure the problem.
Old Jan 23, 2019 | 05:33 AM
AndrewPike's Avatar
What do you mean correct fuel C—? Also is setting the iac after adjusting tps a must? Also is it possible that 60 psi idling is the actual pressure and when I just key the pump on, it doesn’t have enough time from the relay to get to 60?
Old Jan 23, 2019 | 10:23 AM
AndrewPike's Avatar
Ok so another opdate, i tried driving it today and it runs horrible, but i was backing it into my garage and i reved it a few times to keep it running and it puffed out a large cloud of black smoke, enough to fill my garage. So im guessing its still insanely rich and ill have to adjust my fuel pressure down more.
Old Jan 24, 2019 | 04:09 AM
"What do you mean correct fuel C—?"
Sorry a few years since I did this, 500KQs don't have an adjustable TPS, and everyone buys 500KQs round here now, with fuel at £5 a gallon. I meant -COO settings on the speedo. See this video https://www.google.com/search?q=Sett...TF-8#kpvalbx=1 if you don't know how to do it.
Old Jan 24, 2019 | 07:57 PM
AndrewPike's Avatar
Oh yes my tps is adjusted properly -COO
Old Dec 8, 2024 | 12:34 PM
Cboettler's Avatar
Have you figured out what was the problem my dad's king quad is doing the same thing?
Old Dec 8, 2024 | 02:36 PM
AndrewPike's Avatar
I ended up going back to the stock fuel pump with a new sock/filter on the pump and she was good to go.
the Aftermarket pump with modded oring would not work correctly.
Old Dec 8, 2024 | 02:40 PM
Cboettler's Avatar
So his fuel pump could be the problem sounds strange he can shut it off while it's sputtering and restart it and it will run fine for a while then it sputters again. I'm thinking that when it shuts off it's clearing the filter and when it runs maybe it plugs up again idk
98KingQuad
Aug 29, 2010 08:50 AM
yamakatz
Feb 15, 2010 01:43 PM
Pete2411
Feb 22, 2007 11:48 PM
Bubbaman
Aug 7, 2005 01:44 AM
w1ngnut
Jul 19, 2005 12:32 AM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
