2003 LTF400 Eiger Rear Axle Removal
Old Oct 25, 2021 | 04:31 PM
Andy LTF's Avatar
Default 2003 LTF400 Eiger Rear Axle Removal
Hi Guys,
I am swapping my shot rear bearings out with new and the left rear bearings are rusted in place currently.
I now need to remove the left axle from the housing in order to punch the bearings out. Does the left axle simply pull out (using the end thead located in the axle to wind it out of the diff?)
I've already removed the bearing circlip and unbolted the left side axle housing.
Thanks,
Andy
Old Oct 26, 2021 | 04:03 AM
The LH axle tube just pulls out of the diff, wiggle it sideways a bit to free it if it is tight. Half shaft is just loosely splined into diff, that outer bearing keeps it in place.
Old Oct 26, 2021 | 08:22 PM
Andy LTF's Avatar
Thanks!
A bit of tapping and pulling on the axle and it came out no problems.
Tmetz
Jun 7, 2011 11:11 AM
alex288288
1) Engine problems..
May 7, 2010 06:34 AM
Crimedog
ATC 3-Wheelers
Aug 26, 2003 11:53 PM
Scootter
Sep 23, 2002 01:35 PM
