little problems
Old Jul 21, 2001 | 12:55 AM
northerquadzilla's Avatar
i have an 88 quadzilla thats worek great except for when i am in first and second gear i have to rev the crap out of it because it kind bogs i guess you could say does anyone have a fix????
Old Jul 21, 2001 | 05:34 PM
bermbanger's Avatar
You probably need to check your jetting.
Old Jul 21, 2001 | 10:22 PM
RdingManiac420's Avatar
This would probably be cause by the idle screw. Do a plug chop and see if you need to lean or richen it out. The idle screw changes the low end power hit so that may be your prob.
Old Jul 23, 2001 | 02:08 AM
RideRed04's Avatar
Yeah right, why wont you guys just admit that the quadzilla is down on power?! I mean come on! A 500cc 2-stroke, I have 2 more strokes that you, and that means I have more power! (I am just kidding, dont get offensive!)
Old Jul 23, 2001 | 11:58 AM
robnhouston's Avatar
RideRed..your atv is yellow? (just kidding).
I don't believe the air idle mixture screw will do anything for your low end. It's just that..an idle circuit. Once you step on it another fuel/air circuit takes over.
Remember low end power is not a positive trait of most 2 strokes.
Rob
Old Jul 23, 2001 | 05:49 PM
markdf's Avatar
The idle circuit (controlled by the idle screw) is only used when the throttle is closed to about 1/4 open. Then the needle jet circuit takes over until about 2/3 throttle, then the main jet.
Mark
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
