Lt230 NEED HELP rings
Old Dec 20, 2003 | 12:49 AM
lt230racer's Avatar
Default Lt230 NEED HELP rings
i've been running synthetic in my 230s and havent noticed anything bad, i never knew syn. oil did that to oil seals. all ive heard is that it makes your clutch slip, but i got the SPECIAL oil.also, the 230s should be no problem to do yourself it isnt that complicated.
Old Dec 20, 2003 | 09:37 AM
Vinson581's Avatar
anyone think of anything for my post?
Old Dec 20, 2003 | 10:25 AM
Vinson581's Avatar
no no , it smoked just as bad as before, so i shut it off, and i am going and getting a new sleeve installed, as well as the valves seals. i did not want to damage brand new rings, and piston, so i shut it off.
Old Dec 21, 2003 | 05:50 AM
MBrooks420's Avatar
I would think your rings are fine, unless the cyclinder walls were bad, and chipped the rings. I WOULD NOT run the bike hard after the first warm up. I would follow the traditional break in period that is almost always reccomended.
Old Dec 21, 2003 | 05:52 AM
  #15
MBrooks420's Avatar
ThequickOne- have you ever had a motor apart before? The 230 isn't all that difficult, but bieng a 4 cycle there is a lot of stuff that could be messes up. I highly recomend a camcorder, or a digi cam and a ton of pics showing how everything went. I'd have a compression test done, it may not be the rings, and may just be valve seals.
Old Dec 21, 2003 | 10:46 AM
  #16
Vinson581's Avatar
thanks again mbrooks. i am returning my la sleeve, because fact is it does not fit, damn. so what i am doing is just getting the thing bored .20 over, and getting a weisco piston kit 20 over, i guess. the valves are great, reason i say that is because, the motor it was pulled from just threw a rodm but never smoked, and used to start right up.
Old Jan 2, 2004 | 01:52 PM
  #17
Vinson581's Avatar
my 230 is bored .20 over, insted of new piston and rings and bore, i talked to a guy and he said do a oversize ring .25 and a light hone, sound right?
lonerider856
Oct 13, 2023 03:45 PM
Joe454
Nov 20, 2020 01:19 PM
dunerv8
Technical and How-To Articles
Sep 14, 2015 10:11 AM
nastyblaster100
Sep 13, 2015 01:19 PM
bvolks
Sep 13, 2015 12:57 PM
