How do I determine the model year of a Quadzilla?
Old Feb 20, 2003 | 11:13 PM
TomM's Avatar
Default How do I determine the model year of a Quadzilla?
How do I determine the model year of a Quadzilla? The seller said he was told it is a 89 but is not sure.
Old Feb 20, 2003 | 11:17 PM
donzilla's Avatar
two ways . look at the a arms . if the top arm is solid all the way across . its an 87 . if it mounts in two spots (one for each side of arm)its an 88-90 . also the 87 had 6 head studs . the 88-9 7 . other than that have to check the vin code . the suzuki dealer has that on file . hope this helps .
Old Feb 21, 2003 | 12:29 PM
TomM's Avatar
Thanks. Im pretty sure it has the solid a arms.
Old Feb 21, 2003 | 02:16 PM
LEP7MM's Avatar
another way to describe the front A-arms is they used a rectangular tubing in '87. They switched to a round tubing in '88. The head studs is also correct, 6 in '87, 7 in '88 and newer.
Old Feb 21, 2003 | 08:55 PM
Zoinks!!!'s Avatar
On the VIN # what is the 10th digit or letter? This will tell you what the year is! I will have to find my book to exactly what # or letter represents 1989.
Old Feb 21, 2003 | 09:06 PM
TomM's Avatar
The a arms are solid across the top and square, the 10th letter is "H" and it has 7 head bolts.
It may be an 87 frame with a later model motor.
Thanks.
Old Feb 21, 2003 | 09:25 PM
Zoinks!!!'s Avatar
H does mean 87.
Nondem
Feb 22, 2020 12:20 PM
RickyMac
Mar 5, 2016 07:27 AM
Riding Gear
Jul 16, 2015 10:39 AM
John Boy
Jul 13, 2015 11:16 AM
black_thunder
Jul 12, 2015 11:04 PM
