suzuki problem !!!!!!!
Old Mar 18, 2003 | 06:06 PM
Cobra14's Avatar
Default suzuki problem !!!!!!!
my 230 quadsport burns alot of oil can any body know why please help?/??????[img]i/expressions/face-icon-small-confused.gif[/img]
Old Mar 18, 2003 | 07:53 PM
Eiger4x4's Avatar
Blowby? Bad Valve Seals?
Old Mar 18, 2003 | 08:24 PM
aksledder's Avatar
Burns oil, so this means you see a bluish gas leaving the tailpipe? Do you have a compression gage or a leak down gage.
Need more details from you!!!
Old Mar 18, 2003 | 08:25 PM
Cobra14's Avatar
it just smokes and burns oil
Old Mar 18, 2003 | 10:00 PM
b1yjg51's Avatar
I have two of these, an '85 and an '87. The valve train is pretty good, and unless you are running it extremely lean (to where it will almost not run) the valves won't burn, The guides are also pretty tough. However, they need clean oil, the cylinders and the rings can go bad quickly and get sloppy. Going one more size over on the piston and rings, with a bore job will do wonders. You are looking at about $125 for the machine work and the parts. While you have the jug and the piston off, take a lok at the head and valve train. With the piston and cylinder off, you can also check for play in the connecting rod bearing.
Good luck
jaime511
Jul 19, 2015 01:58 PM
Jul 15, 2015 02:07 AM
clsharky
Jul 13, 2015 02:07 PM
sara durrant
Jul 6, 2015 05:32 PM
bikedad3
Jul 2, 2015 02:15 AM
