Does this mean my clutch is out?
I was out riding my LT250R and its was running good. Then it started acting up. When I put it in first gear and let off the clutch it dies. If I rev it up and let off the clutch it bogs down and then dies. I hope this is just the clutch since I have a new clutch kit for it already. I was wondering if this sounds like a clutch problem or something else? It idles and revs fine in neutral.
Thanks
Thanks
But if it's under stress/load it dies when you try to get it moving? If so, check the compression/gaskets/seals. You might have a leak, my 2-stroke Scrambler did that, would idle fine, rev up basically normal, but under stress it would bog out and die. I ended up having to replace the base gasket. I think someone wrote something about a cracked pistion doing that too. I wouldn't run it until you are able to check it out, incase it would cause more problems.
Ok...could this problem just be the clutch, or do I need to look deeper. Am I wasting my time just replacing the clutch or should I rip her down and replace the seals and gaskets. If it was a leak would it run fine and then just stop working like it did? Any help would be great!!!
cdstang
Aug 31, 2015 07:52 AM
