How can I tell what year my lt250r motor is?
Old May 3, 2003 | 02:28 PM
Treedogg's Avatar
Default How can I tell what year my lt250r motor is?
I was told that my lt250r was a 91 when I bought it used but when I put new seals in the motor one of them didn't fit. Can you tell by the serial number on the motor?
Old May 3, 2003 | 02:39 PM
TomM's Avatar
I dont know if there is a way to tell from a serial # or not, but there are ways to narrow it down. If it has a power valve than its a 87 or newer. I dont think the motors changed after that in any way that would affect the shape of the seals but am not positive. Somebody with a better knowledge of later model Quadracers might be able to tell what year if they knew which seal doesn’t fit.
Old May 3, 2003 | 02:59 PM
Treedogg's Avatar
The inside diameter of the counterbalencer seal is 35mm where the counterbalencer shaft and bearing is both 25mm so that seal set was definitely not the year of my motor. It does have the power valve.
Old May 6, 2003 | 09:32 AM
HUEDOGG's Avatar
if it doesn't have a powervalve than its an 85-86' .
Old May 6, 2003 | 10:55 AM
TomM's Avatar
If all the seals fit but one, it could have been a mistake at the warehouse.
John Boy
Jul 13, 2015 11:16 AM
rcappie4
Jul 10, 2015 04:54 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
bikedad3
Jul 2, 2015 02:15 AM
