Technical and How-To Articles Post your Tech Tips and How-to articles here. Photo illustrations welcome
honda 400ex wont start
Old Dec 26, 2012 | 11:59 PM
nschlicksup's Avatar
Default honda 400ex wont start
2002 400ex just clicks when u try to start it. Never actually turns over. I charged the battery full, took outthe carb and its perfectly clean. Even tried using starter fluid but nothing worked it still just clicks. Someone please help!
Old Dec 27, 2012 | 09:44 AM
Koopa's Avatar
Is addicted to 4 wheel'n!
I'd try to pull start it to get it running. Starter fluid and carb cleaning won't help you if the engine won't turn over.
Did you check the battery? You can put it on a charger but, if the battery is bad it's still not going to hold enough charge to start the machine. If it has set very long you probably need a new battery.
Old Dec 27, 2012 | 10:39 AM
The batterys only a couple months old but i checked it anyway and it says its at 90% so it should start. And i dont have a kick start unfortunatley
Old Dec 27, 2012 | 10:54 AM
Koopa's Avatar
Could be the starter solonoid. Put a pair of jumper cables directly to the starter if you can. If it spins and the engine turns over know your starter is good. Or maybe do the old screwdriver across the solonoid trick.
Like i said before you could pull start it if you want to see how it runs.
Old Dec 29, 2012 | 01:34 AM
Its a brand new starter relay so im almost positive now that its my spark plug but i cant figure out how to get the spark plug out to check it?
Old Dec 29, 2012 | 03:07 AM
95wolv's Avatar
If the starter is just clicking, a new plug will do nothing. get it running with a pull start, as mentioned, or pull out the starter and see if it turns over when out of the motor, maybe you have a bad starter , or something is causing the motor to lock up so the starter cant turn it. Just 2 bolts and the starter comes out, then just ground the case and see if it spins over when you push the button.
Old Dec 29, 2012 | 11:18 AM
Koopa's Avatar
I would suggest you get a Haynes Manuel for the quad. these 400s aren't to complex but a lack of experience could do more harm than good.
as said the spark plug has nothing to do with the engine turning over. The starter needs to be checked.
neilbedwell
Nov 10, 2018 11:02 AM
DTroyer01
Jul 3, 2015 07:34 AM
1000gade
May 27, 2015 12:37 PM
lovinhonda
Jan 25, 2000 09:17 PM
roktoy
Aug 25, 1999 04:37 PM
