Technical and How-To Articles Post your Tech Tips and How-to articles here. Photo illustrations welcome
Glad to be here! Please help!!
Old Jul 18, 2013 | 04:14 PM
cforno1988's Avatar
These two do not go into the kill switch/headlight switch assembly.
Old Jul 18, 2013 | 04:49 PM
Originally Posted by cforno1988
Ok I have two wires, one brown and one green. Both leading to the left brake handle, what do I need to do in order to get this quad running?
Order the switch I posted a link to. This needs to be on the machine as a safety feature.It's a starter safety switch that allows the starter to engage only when you pull the brake lever! If afterwards it still doesn't engage the starter,then it could be a bad starter relay(mounted under the seat on Polaris,don't know on Eton) or starter motor itself...
Old Jul 18, 2013 | 04:54 PM
cforno1988's Avatar
Ok... But why would I need to order the switch when those two wires are no where connected to the kill switch assembly? For now so I can get the carb adjusted is there anything I can do with the brown or green wire to start the quad?
Old Jul 18, 2013 | 05:10 PM
The starter interlock switch comes with new wiring in place of the two wires you have. All this safety plunger switch does is to stop starter engagement unless you pull the brake lever. You can kick start it (if you have one) as this plunger and wiring doesn't have anything to do with the ignition,just the electric starter part of it. You can tie the two ends of the tether safety switch together to eliminate it as a problem on testing ignition,BUT again it's a safety device also,if bad I'd replace it also.
pgamboa
Dec 24, 2023 11:52 AM
dannytas
Sep 26, 2017 06:31 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Polaris Side by Sides
Sep 15, 2015 03:33 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
