Technical and How-To Articles Post your Tech Tips and How-to articles here. Photo illustrations welcome
tail light issue
Old Feb 4, 2019 | 05:25 AM
mrgjag's Avatar
Angry tail light issue
Hi, I have a 2008 Polaris Sportsman 500 H.O. and I don't have tail lights. I have brake lights and head lights I just don't have tail lights. Is there a fuse for these and if there is where is it located. Thank you.
Old Feb 4, 2019 | 06:17 AM
scootergptx's Avatar
Supersock
Hired Gun!
Welcome to the forums.
I don't have this model, but the first thing I'd check would be the bulb. If it's just a one filament bulb, then it's only going to have break lights. If it's a two filament bulb, then you should have a running light. If the bulb is good, I would think it's going to be a wiring issue. If there is a fuse for the tail light, I'd bet it would be for both and not separate.
Old Feb 4, 2019 | 04:23 PM
Big Frank's Avatar
THE BERMINATOR
Veteran: Army
5 Year Member
I don't know if Polaris ever made an ATV without tail lights but I've never seen one. I would pull the bulbs out and check them first too. I use an ohm meter whenever I check light bulbs, whether they're in the house or on a vehicle. I don't care how many ohms it is. It's either an open or a closed circuit and that's what matters to me. If it's like my '08 EFI the fuses are behind the radiator cap. Open the front cargo box and pull the cover. Spare fuses should be on top of the cover if it's like mine. But I think it's one fuse for brake lights and tail lights since they're in the same pair of bulbs. It wouldn't make sense for there to be 2 fuses for them.
Old Feb 5, 2019 | 06:09 AM
Kymco 450i's Avatar
All offroad vehicles are required tail and headlights as well as brake lights unless it is a little kids model. Has been that way for a long time. On my Kymco there are seperate fuses for tail and brake lights....one for each filiment in the bulb.
James Lord Sr.
Dec 28, 2016 05:20 PM
pennsdalerepairshop
Oct 30, 2010 10:25 PM
TEXASCAT
May 17, 2001 01:09 AM
YaMaRaPtoR!
Feb 26, 2001 12:41 AM
chasman
Jan 12, 2001 12:57 AM
