how heavy
Old May 9, 2005 | 12:13 AM
woodjr's Avatar
Default how heavy
i own a 04 ram 2500 with 5.7 hemi need advise on heavy i should keep my laod too (toy hauller water and quads etc..). and the advantages of 5th wheel vs. bumper hitch.
Old May 9, 2005 | 01:05 AM
BlackandRedWarrior's Avatar
Air Cooled Rider
Future Govenator of Kalifornia!
Default how heavy
Check your door pillar and owner's manual.
You should not exceed your GVWR, GCWR, front and rear GAWR. Or the manufacturers listed tow rating (you will have to exceed the others before you touch this.)
If you have everything, take a trip down to a local public scale and weigh everything. Search around here for instructions or search on google. rv.net has a great forum over there (much like this one) and instructions are there. I've posted it too many times to repeat myself.
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
Old May 9, 2005 | 03:06 PM
woodjr's Avatar
Default how heavy
hey clovis me to
Old May 9, 2005 | 04:25 PM
GreenBeast's Avatar
Default how heavy
Hey bud, I've got an 03 Ram 1500, quad cab, 2x4, 5.7L, regular hitch. Like the other post say's check your door, and owners manual. But I tow a pretty heavy trailer with 4 heavy atv's with no problem. Just make sure you turn off your overdrive while towing and keep your RPM's below 3000, it won't hurt it to go over 3000 rpm's, but i wouldn't want to do it for long periods of time. I assume your truck already has a transmition cooler. You also might want to switch to a synthetic trans fluid. B&M makes some real good fluid and will help keep the temp down.
Old May 9, 2005 | 07:15 PM
Air Cooled Rider
Default how heavy
Wood, there are several public scales around town. Look in the phone book for them. Not sure if anyone is in Clovis per se. Cheapest I found was like downtown Fresno at some place. Can't remember.
Old May 10, 2005 | 11:30 PM
woodjr's Avatar
Default how heavy
what do you mean by long periods when i pull the long hills what choice do i have
Old May 11, 2005 | 04:17 PM
GreenBeast's Avatar
Default how heavy
If you keep the speed under 67 or 68 mph with overdrive turned off you shouldn't go over 3000 rpm, especially towing with a 2500 series, and there really isn't an uphill climb that is so long that it will hurt to have your rpm's over 3000 going up them. When I say for "too long" i mean like over an hour or so. And even then your probably not going to do any type of bad damage, other than a little more engine wear than would normally occur.
Old May 11, 2005 | 09:25 PM
ostrich's Avatar
Default how heavy
dpends on what gears you have, as long as the trans is not hunting around leave it in o.d., remember its not just the weight, also include the frontal area of your vehicle and your load this will also effect your trucks performance. Ford used to have recomendations as far as frontal area,load and truck specs, I would think that dodge also did.
Old May 12, 2005 | 07:02 AM
woodjr's Avatar
Default how heavy
thank you
speedbuff
13
Nov 11, 2020 10:16 AM
STLyamwar
Jul 25, 2020 04:44 AM
badgerboy1
Sep 26, 2017 06:11 PM
95scramblerruben1033
Sep 23, 2015 06:29 PM
CosmoM
Sep 21, 2015 04:57 PM
