Help on loading trailer
Old Oct 21, 2007 | 11:47 PM
tooldood's Avatar
Default Help on loading trailer
I am trying to load to quads into a 5x8 trailer. The quads are: Raptor 350 and 660.
Anyway I can get both in loaded in the trailer??
Old Oct 22, 2007 | 03:45 PM
dwhst9's Avatar
load them sideways
dwhst9's Avatar
load them sideways
Old Oct 22, 2007 | 07:39 PM
tooldood's Avatar
Thanks. Trailer is not wide enough to load without the quads up on the rail...
Do you know how the quads being up on the rail will affect the trailers ability to trail my truck alright??
Old Nov 28, 2007 | 12:43 PM
camyow's Avatar
get a bigger trailer
Old Nov 28, 2007 | 01:03 PM
deanz400's Avatar
I've loaded many ATV with one side on the rail ,but do look into getting a big trailer .if you have a truck load one in there .
Old Mar 15, 2008 | 08:30 PM
spoolnaround's Avatar
sawzall, welder and more steel.
Old Mar 15, 2008 | 08:47 PM
jaybeecon55's Avatar
Sound advice there. "Hey, watch this........"
If you want to get a little creative:
Get four 2x8x6' or four 2x10x6'. Bolt them across the top of the trailers side rails - one board across the very front, one across the very back and the other two side by side across the middle. Use a ramp to drive each ATV on top of the planks from the side. Tie them down very well. Even better - get a bigger trailer.
Or, take two planks, each at least 5' long. Place one end of one plank on the trailer deck with the plank resting on the front rail of the trailer - it will be at an angle pointing up over the tongue of the trailer. Put the second plank in a similar position - both planks should be the same distance from the center of the trailer and the same distance apart as the width of an ATV. If you use 5' long planks then have 3' of the plank over the trailer and 2' overhanging the tongue. Drive the first ATV onto the trailer and up on to the two planks. Since you will now have about 5' of trailer available behind the first quad, drive the second quad onto the back part of the trailer. Strap them down really well. Even better - get a bigger trailer.
In checking the post dates I'll hope that since October of last year you got another trailer.
Jaybee
Johnny Mac
60
Dec 14, 2019 06:13 PM
dannytas
Sep 26, 2017 06:31 PM
badgerboy1
Sep 26, 2017 06:11 PM
Dewhound
Apr 20, 2017 02:25 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
