Winch mount on trailer
Old 03-17-2008 | 10:20 PM
tydogg's Avatar
Default Winch mount on trailer
I have just bought a new trailer and i am planning on putting a ATV winch on the front of the trailer to pull on dead quads and snowmobiles . I am wondering the best way to wire it. Should i run wires from truck battery to the bumper with a female plug and a male plug on the winch? Will this work and is there a plug you can buy special for this install? Thanks
Old 03-17-2008 | 11:00 PM
LittleBill's Avatar
honestly you can do it, but i would rather a separate battery all together, then simply charge it from the truck. i have seen my winch pull over 40 amps, which would prolly require 8 gauge from the front of the truck to back
Old 03-17-2008 | 11:26 PM
tydogg's Avatar
how did you wire that setup for the best outcome?
Old 03-18-2008 | 12:11 AM
upnort's Avatar
If you wanted to go much easier with about same results maybe try a crank type boat winch like you see on boat trailers. I am sure you would not be using it that much. I believe they are like 2000# enough to pull a boat on trailer.
Old 03-18-2008 | 12:12 AM
upnort's Avatar
That sounds good enough I may do it. Have had to winch a machine on my tilt bed trailer twice.
Old 03-18-2008 | 10:18 AM
deanz400's Avatar
I've used a comalong rachet to pull a dead machine up
Old 03-20-2008 | 11:45 PM
vinman18's Avatar
i think the best way is to put a car battery on your trailer by your winch. and charge it after uses.
Old 04-15-2008 | 02:54 AM
ericgiroux69's Avatar
Hey you should use this just run wires from the battery in your truck toi the back and put that conecter on it then wire your winch up all you need to do is plug it in when u need ut and unplug when you dont Text
Old 06-15-2008 | 02:51 AM
TomM's Avatar
Ive been thinking about a boat winch. Ive never needed it before but they are cheap and I figure its beter to get such things before the one time you ever need it then after.
Old 06-15-2008 | 09:27 AM
rescuediver's Avatar
Why don't you try an electric winch like this?
electric winch
I used one for a couple of years loading my atvs on to a rack I had in the back of my truck. Worked just fine[img]i/expressions/face-icon-small-smile.gif[/img]
95wolv
09-27-2024 01:00 PM
Johnny Mac
60
12-14-2019 07:13 PM
Johnny Mac
08-15-2019 04:13 PM
badgerboy1
09-26-2017 07:11 PM
EIF
04-20-2017 08:15 PM
Quick Reply: Winch mount on trailer
