Winch Rope?
Old Nov 26, 2004 | 12:28 AM
Rubidude's Avatar
Default Winch Rope?
BigBear03...The best way to reel in winch cable is under load. If a cable is wound on loosely, it may bind up on itself as the tension increases when you use it next. That's when kinks and "birdnests" happen. What works for me is to unreel the cable completely leaving at least 5 wraps on the spool. You can either hook onto a heavy object, and pull it toward you, or hook onto in immoveable object and pull yourself toward it while holding the brakes slightly. As long as you steer directly towards the object you are hooked to, the cable will generally wind itself on neatly, and tightly.
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
Johnny Mac
Aug 15, 2019 03:13 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
cboler9
Sep 24, 2015 08:35 PM
Alex G.
Sep 19, 2015 06:34 PM
