Warn 4-2-4 Problem. Please Help!!!
Old Jul 29, 2005 | 10:02 PM
MrBaldone's Avatar
Default Warn 4-2-4 Problem. Please Help!!!
I want to reroute the cable on my warn 4-2-4 to make room for a winch. The directions say to remove small set screw on red button and remove red button and screw. I removed the set screw but the red button won't come off. The 4-2-4 was on the atv when I bought it therefore I don't know how it was installed. Please help.
Old Jul 30, 2005 | 11:01 PM
650cc's Avatar
Is it in 4 wheel drive or taken out??
I think it needs to be locked in 2 wheel drive or 4 wheel drive I cant remember
I had to fool with mine alitte while ago
Old Jul 31, 2005 | 10:44 PM
LittleBill's Avatar
it doesn't matter, the button unscrews counter clock wize from the black button, after the screw is removed, then remove the 2 main nuts, big and little,push the brass level foward and release from the cable, be careful there are 2 ***** that are used to lock in 4x4, be easier to do it while engaged in 4x4
Jeff Roper
Feb 1, 2022 11:48 AM
Beeline08
Nov 11, 2016 04:00 PM
shimanok2
Jan 29, 2016 07:37 PM
panicmanic
Sep 28, 2015 12:59 PM
JDawg8309
1) Engine problems..
Sep 12, 2015 02:24 PM
