Plow mount advice
Plow mount advice
I bought a 2008 300cc Polaris Hawkeye and also picked up a used plow. I am not sure where to pick up the correct mounting hardware, any advice?
I have included pictures of the plow connectors, it looks pretty basic but I'm not sure how to find the correct mounting hardware.
You'll also need a lifting mechanism, you can use a winch, an electric actuator (basically a little winch that mount where the pulley sits now), or a manual lift (you have the weight of the blade to lift with your arm). The actuator also requires a bracket that mounts on the front rack to relocate the pulley
