oil leak, help please.
Old May 25, 2003 | 05:25 AM
Ward660R's Avatar
Default oil leak, help please.
I have an oil leak on the bottom banjo bolt in the case. I did not use new crush washer when I put it back in last time, I know I know. So now I am going to replace them. BUT my question is, will I lose my $6 a quart oil when I take this bolt out to replace them? I know I will lose a little but how much? Should I just go ahead and drain it all first?
TIA
Old May 25, 2003 | 08:01 AM
Guest
Guest
Posts: n/a
you shouldn't lose all of the oil when you take the bolt out. BUT i am not positive. Just to be safe and not have oil going down your arm or all over yuor floor I would drain all of the oil first, you can always put it back in when you are finished,
Patrick
Old May 25, 2003 | 02:05 PM
sixsixT's Avatar
Which line?
Old May 25, 2003 | 02:47 PM
wshrdskin's Avatar
You'll only lose the oil that is in that line and behind it inside the case that that line feeds until the level in the motor is at the level of the bolt you just removed. If its the one between the clutch cover and top of the right case then you'll lose less. If its the one from behind the water pump area to the head you'll lose more cause the line is longer and you might lose a little from the cam area also. But either way you won't lose much and if your fast enough you'll lose less. [img]i/expressions/face-icon-small-wink.gif[/img]
Old May 25, 2003 | 03:59 PM
Ward660R's Avatar
Thats exactley what I wanted to hear. Thanks alot!!![img]i/expressions/face-icon-small-cool.gif[/img]
exmotocrosser
Sep 13, 2019 06:12 AM
Scooter's Shop
Oct 9, 2015 02:09 PM
wrencher82
Sep 24, 2015 03:39 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
Pahuntman
Sep 5, 2015 11:07 AM
