blaster mods for sand.
Old 05-07-2000, 04:37 PM
TopDawg's Avatar
Hi I normally post in the honda forum but ran out of things to read so I read some yamaha posts and was happy and impressed with the honesty and maturity. Instead of saying honda 400ex sucks most complemented it's good points. Any way my wife has a blaster and it's fun but we would like to increase the power to keep it closer to my 400ex on the dunes. What mods really make a big difference other than tearing into the engine?
Old 05-07-2000, 06:00 PM
94DGblaster's Avatar
If it is all stock, i would say just get a pipe, and rejet the carb.
If you want to spend 900 on it. The CT240 kit would get it moving.
I've heard these kits will go around 80!
Old 05-07-2000, 08:24 PM
Ryan88Blaster's Avatar
If you don't want to spend alot of money you can get some poor man's horsepower......Reduce the weight.you can remove front fenders,autolube (be sure to make a block off plate and mix gas),aluminium bars/wheels,take off the light,remove the tors system,any unneccessary wiring,parking brake. After that is done look into a pipe. My fmf really woke up my blaster.Also since you ride dunes and won't be seeing alot of water a k&n air filter w/no airbox would definitly help.don't forget to rejet.
Ryan88Blaster
Old 05-11-2000, 12:24 AM
BLASTER_14's Avatar
Don't forget the paddles they really helped my blaster
Old 05-14-2000, 10:59 PM
free1steven's Avatar
Weight savings is the biggest factor for the Blaster. Every pound you can loose off the rear axle like tires, wheels, and hubs translates into a seven pound savings. Just got a set of Skat-Trak gliders in the 18x9.5x8 size and they weigh next to nothing. They also are a six paddle tire with shorter paddles. This would give you better wheel speed. I use Douglas blue label alum. rims for the sand. You could loose a lot of weight going to a shaved front tire also. Aftermarket lightweight hubs will save you about a pound apiece. Pipes are a good idea. Will help performance and save about five pounds. Taking off front bumper and foot peg nerfs will save about five pounds.
Ahtatu
09-28-2015 12:14 PM
09-23-2015 06:23 AM
PrairieDog126
09-16-2015 01:33 PM
nastyblaster100
09-13-2015 01:19 PM
1ArmBandit
09-08-2015 08:59 PM
Quick Reply: blaster mods for sand.
