Ultramatic transmission.
Old Jun 19, 2003 | 06:41 PM
ElectricShift's Avatar
Default Ultramatic transmission.
How do i know when my belt needs replacing?
Old Jun 19, 2003 | 10:09 PM
Vakero's Avatar
Assuming that an 02 600 Grizz uses the same drive belt as an 03 660 the measurement specs should be correct.
1- Remove the v-belt from the sheaves and inspect the inner side ( side with the teeth ) for cracks/wear/scaling/chipping replace if something does not look right.
2- Measure the width of the v-belt with a micrometer. A new belt should be 33.2 mm (1.31 in)
The wear limit is 29.9 mm (1.18 in) If it is worn beyond that replace the belt.
The measurement is taken at the outermost angles of the belt.
While you are there you should clean out and regrease the primary and secondary sheaves.
You will need a manual/ or service cd and tools to do the job. Post back on the progress or if you have questions.
cornermike
Aug 10, 2016 06:47 AM
MrT
Jun 21, 2001 07:13 PM
rogi
May 2, 2000 09:21 PM
BigDogs
Apr 6, 2000 12:53 AM
BEARUS
Apr 5, 2000 10:25 AM
