yz 450 cam vs adjusting exhaust cam
The cams are all the same (lift and duration). The only difference is the decompression pin location. WR won't start if you change the timing, but the YFZ battery is larger and spins the motor faster, so it works fine. You may not want to make the adjustment until you get a pipe, changing the cam timing takes from the bottom and adds to the mid/top. with a pipe there is so much increase in the bottom that it compesates for it.
Hankey Pankey
05-01-2018 01:33 PM
Hankey Pankey
08-17-2015 05:01 PM
bpegram84
07-22-2015 08:15 AM
