FCR=Friggin Crap is Retarded
Old 07-23-2003 | 09:06 PM
RacinJason's Avatar
Default FCR=Friggin Crap is Retarded
Lets see I just spent $730 on a set of carbs that didn't fit my quads frame
a set of carbs that don't bolt up well with the intake manifolds(more sketchy than the stockers)
oh yah and they interfere with the exhaust...
could be the carbs are retarded...but after forking out all that cash I think I'm retarded
Do you know how much heroin I have to sell at the elementary school to make that sort of money[img]i/expressions/face-icon-small-wink.gif[/img]
Old 07-23-2003 | 09:10 PM
StockRappy's Avatar
if it was suppose to fit i would send it back to the guy u got it from...
Old 07-23-2003 | 09:15 PM
howardstern's Avatar
just get the manifolds from trinity it set's them back and to the left more room all around. you might have to put spacers and longer bolt's on the silencer to get the pipe away from the carb's!! that what I had to do!
RacinJason's Avatar
appearantly they don't fit...you just modify everything you already have to fit it...wise-*** aftermarket companies
Old 07-23-2003 | 09:38 PM
fitoo's Avatar
If you would have done a search on FCR's or read anything on this board for the last few months about FCR's you would have been prepared for the fact that they take some fitting. Hi Performance folks, that $hit takes a little bit of work and elbow grease. The Trinity manifold and adapters make quick work of fitting them on your quad, as for them not clearing your pipe DUH! Everyone that has said anything on this forum about FCR's and installing them has said it, you should have known you were gonna have to pinch the pipe, otherwise engineer it to get the accel pump to clear. With all this information at our fingertips it cracks me up how it goes right over some peoples head. UBETRUN not a month ago had several extensive posts about how to make FCR's fit, took pictures and everything. [img]i/expressions/face-icon-small-wink.gif[/img]
Old 07-23-2003 | 10:02 PM
warrior007's Avatar
ruff day at the office?
Old 07-23-2003 | 10:27 PM
UBETRUN's Avatar
You have to install a couple of washers on the right side of the frame crossmember and pinch your pipe less than 1/4", well worth the effort once you get it going again. Just wait until you hit the throttle the first time, that little accelerator pump is worth the extra work. According to Sparks, they could never get the same HP out of an extended intake manifold as the stockers. I had just bought UPP carb boots so I opted to make them work. I had to apply a lot of muscle to get them into the UPP carb boots but I don't think they will ever work loose. Also, the Sparks X-6 pipe will clear the accelerator pump if you feel the need to spend more money.
I've got a bunch of pics at http://www.imagestation.com/album/?id=4289764209
BTW, you got a hell of a deal! Sparks was the cheapest I found and they were $799 before shipping. What are your mods and what jets came in your carbs?
Old 07-23-2003 | 10:58 PM
Turbo33's Avatar
Wow, This post really surprized me.
I have had no problems with my FCR's I simply put them on the 02 with stock boots and I have had both Trinity's pipe on and the HMF pipe and I can't see where the problem could be.
Old 07-23-2003 | 11:34 PM
UBETRUN's Avatar
The Sparks tech said that some Raptor frames were tighter than others and some pipes interfered and some didn't, I guess you got lucky:-)
Old 07-24-2003 | 12:56 AM
WallStreet's Avatar
I'm gonna call the cops on you. [img]i/expressions/face-icon-small-happy.gif[/img]
Quick Reply: FCR=Friggin Crap is Retarded
