wolverine problems
Old May 25, 2000 | 10:13 PM
yamahon's Avatar
how much will it cost to replace the right front wheel bearings and how much do u think a mechanic will charge to put them in?
could a torn cv boot cause bearings to go out?
how much does a mechaninc charge for a new cv boot?
Old May 29, 2000 | 12:31 PM
wolfy's Avatar
THe bearings and seals should cost any where between $30-60. THe mechanics cost would probably be for 1.5 -2 hours labor. THe cv boot shouldn't cause the bearings to go out only the seals would do that.
Old May 29, 2000 | 10:11 PM
boomer's Avatar
I put sealed front wheel bearings in mine. I got the bearings for about 9 bucks a piece. Requires 4 of them. Seals were around 12 bucks from dealer. If you ride alot in mud and water, get the sealed bearings.
Old Jun 3, 2000 | 08:45 PM
goblin's Avatar
A torn cv boot wont make your bearings go bad, what will go bad is the cv joint, and the outside joint is not replaceable. You have to buy the whole shaft. A new boot is around $50. dollars. I had my front bearings replaced and boot one time and it ended up costing $300. From that point on I do all my own work. You need to replace the boot. Because a new shaft will cost you a whole lot more then a boot and the time it takes to replace. It's easy to do.
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
