Good or Bad Idea
Old Aug 13, 2003 | 09:03 PM
sixsixT's Avatar
Default Good or Bad Idea
I slotted the two mounts and grommets that hold the front of the gas tank so I can slide the tank out by just removing the seat, plastic under the cap, three bolts and the fuel line and slide it out. Anyone else tried this?
Old Aug 13, 2003 | 09:08 PM
UBETRUN's Avatar
Sounds like a good idea, what are the 3 bolts (1 at the rear of the tank, the other 2 are??)
Old Aug 13, 2003 | 09:31 PM
sixsixT's Avatar
The two bolts that hold the rear of the front plastic.
Old Aug 13, 2003 | 09:32 PM
wshrdskin's Avatar
The three bolts would be the three that hold the tank on. I'm not at my quad and can't remember but, can you even get to the front two bolts on the gas tank with the front plastic on? I guess you can SixsixT is doing it. That'd save some time during re jetting for sure. [img]i/expressions/face-icon-small-smile.gif[/img]
Old Aug 13, 2003 | 09:49 PM
wshrdskin's Avatar
Then maybe not. LOL
Old Aug 13, 2003 | 09:51 PM
sixsixT's Avatar
No the front two bolts stay in and tight and the slotted part slides in and out of those.
Save time adjusting the intake valves when doing maintenance too.
Works good so far but I haven't tried it with the plastic on yet, doing some engine mods so I have the plastic off right now.[img]i/expressions/face-icon-small-wink.gif[/img]
Old Aug 13, 2003 | 11:12 PM
warrior007's Avatar
Great idea, for some reason as soon as I take those 2 bolts off the one of the spacers always gets lost. Is there enough room to slide it in and out without bunching up the rubber gromet? Maybe get bolts just a hair longer and double nut it from the bottom if thats a problem for just a hair more room and movement in the metal spacer (so it can turn)?
That is an excellent idea, just spread the plastic and pull the tank out the back, I love it. Great time saver.
Old Aug 13, 2003 | 11:56 PM
sixsixT's Avatar
LOL Yeah those little spacers like to go rolling all over the garage floor.
I tapered the front of the grommets a little on the grinder and will use a little wheatherstrip adhesive to make sure they stay in place, but haven't needed it with 6 or 8 trial fits.
It doesn't seem to need any more heighth with the spacer.
txkevin
Sep 21, 2015 02:02 PM
hoopduerr
Jun 2, 2015 09:01 AM
hoopduerr
Jun 1, 2015 08:22 PM
neilbedwell
May 29, 2015 02:24 PM
Dpearson03
Utility ATVs
May 29, 2015 04:51 AM
