Warrior 12 tooth front
Old Oct 1, 2003 | 10:33 AM
NLWarrior01's Avatar
Default Warrior 12 tooth front
Hi all,
I'm sure that this question has been asked a meeeelion times already but I have to ask it again ..
The stock front sprocket is a 13T on the Warrior .. how much difference will going to a 12T make? Will it be really noticable or will the difference be minimal? My current setup is listed in my sig ...
thanks in advance for your help!
T
Old Oct 1, 2003 | 11:07 PM
Crotts's Avatar
Going down to a 12t, you will loose around 5mph off your top end but yot will gain more torque
Old Oct 2, 2003 | 06:21 AM
Thanks Crotts, is it a noticible difference in the low end. I expected to loose some speed and that doesn't really bother me .. it's not often I get up around the 60 mark anyway. I want to have better accelleration for short lead jumps and a little extra low end for practising my wheelies .. i find the stock with me on just doesn't really do it that well and I end up pulling my elbows apart [img]i/expressions/face-icon-small-smile.gif[/img]
I wouldn't be bothered to make the swap if it's not a fairly noticable change.
Thanks again,
T
Old Oct 4, 2003 | 03:48 AM
Crotts's Avatar
I never used a 12t so I really cant tell ya. if you had 20" tires I wouldnt recomend a 12t because you would be geared to low and would shift a lot. Because you have 22" it should be fine, all I can tell you is buy a cheap one and try it out
Reactant
Mar 30, 2022 02:08 AM
manuelrivera
Aug 8, 2015 04:34 PM
GNorm
Aug 1, 2015 11:06 AM
Ashley S
Jul 31, 2015 09:46 AM
Reactant
Jul 16, 2015 10:29 PM
