Banshee sucks gas...Whats Wrong?????
Old Nov 3, 2003 | 10:38 PM
PaulV's Avatar
Default Banshee sucks gas...Whats Wrong?????
My banshee uses twice as much gas as my friends with mods does. Im running older toomys and a KnN 2into 1,
could some one tell me what the problem may be? Oh yea, the carbs are stock too. I bought the Banshee used and the only mods that I know of are the Pipes and Filter. can someone help?
Old Nov 3, 2003 | 10:40 PM
RAPTORAZ's Avatar
Are your riding habits the same? Maybe you spend more time with the throttle burried to the stop than him.
Old Nov 3, 2003 | 10:54 PM
PaulV's Avatar
Same riding habits, rode toi the hill then dragged the hill same amount of times and returned to camp.
his tank was almost 3/4s full and mine was almost empty.
Old Nov 4, 2003 | 12:06 AM
WyoDuner's Avatar
Well, it may have the float level set too high and spilling out the overflow tubes or perhaps you are really rich.
Old Nov 4, 2003 | 01:05 AM
PaulV's Avatar
Im running 300 jets, I was running 280s but it ran like crap on the bottom end. When iI switched to the 300s it cleared it up. How do you adjust the float level?
Old Nov 4, 2003 | 01:12 AM
Hayseed's Avatar
I use half-again more gas than my riding buddy but I've got 120lbs. on him. lol
Old Nov 4, 2003 | 01:54 AM
Ernie660R's Avatar
I think it is because you have two carbs??? j/k
Does it smoke like hell at an idle up to quarter throttle?
If so then you have the slides in backwards, in other words the left carb slide in the right carb and vise versa.
Old Nov 4, 2003 | 02:11 AM
PaulV's Avatar
No, it only smokes when its cold.
My shee wont idle when its warmed up, though.
it only idles when I first start it up after it has been sitting over night, so basicly when its cold.
Old Nov 4, 2003 | 03:49 PM
PaulV's Avatar
I know somebody has the answer.
I have had alot of fix it advice from these forums before.
someone please help.
thx
Old Nov 4, 2003 | 04:58 PM
Banshee2003's Avatar
I have a set of pipes on mine and that is pretty much it and I run a 280 main no problems. I would check your carb maybe needs to be cleaned out and floats adjusted. Also you will have issues if your silencer is not packed that might be way you are running at a 300 main. With unpacked silencers you are pretty much running a straight pipe and will have no back pressure. Just a couple of thoughts no guarantees.
Good luck
bmxatv10
Oct 14, 2022 06:23 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
Clint Russell
Sep 25, 2015 03:20 PM
cboler9
Sep 24, 2015 08:35 PM
DM2015
Sep 7, 2015 10:36 AM
