Banshee Expert needed
Old Nov 13, 2003 | 01:11 AM
DIRTYJOE's Avatar
Default Banshee Expert needed
I went riding yesterday and at first I rode it with the choke out until it started running descent and then it wouldnt hardly run write at all. Seemed like I had to keep the choke out or half out for it to even run. It also wont Idle by itself and takes forever to start. It stars to flutter like its not getting enough gas or it is getting to much. can anyone point me in the right direction.
Old Nov 13, 2003 | 01:33 AM
hondaracer305's Avatar
Im no expert, but im pretty sure it has something to do with the carbs if you didnt already know, Ive never had it happen to mine, but mine isnt running good either, it starts giving a low power rev, not even enought to spin tires, looks like were in the same boat [img]i/expressions/face-icon-small-sad.gif[/img]
Old Nov 13, 2003 | 01:42 AM
IBlameTheDog's Avatar
Check your jetting, it sounds like a classic case. My Banshee was so easy to start when jetted properly I could do it by hand. No kidding. Also if you are running the stock carb caps (tors I believe) make sure that they are adjusted properly as this will make it not run at all. Check for vacuum leaks as well around the carb boots and airbox. Temperature and altitude have alot to do with jetting.
Old Nov 13, 2003 | 02:04 AM
DIRTYJOE's Avatar
Thats what I was thinking just neede some other opinions mine arent always that great. Thanks for the replies
Old Nov 13, 2003 | 10:17 AM
Hiram's Avatar
Fuel/carb problems my suggustion is to start "clean" which mean clean everything while inspecting, clean the carbs and blow air throw all passages and then clean and make sure the air filter is not torn and doesn't have holes.
jrooker6
Ask the Editor
11
Apr 21, 2016 07:35 PM
sara durrant
Jul 6, 2015 05:32 PM
tweeder
Jul 5, 2015 01:57 PM
Mphillips
Jul 2, 2015 07:20 PM
