DP clutches in warrior
Old Nov 15, 2003 | 08:46 PM
Crotts's Avatar
Default DP clutches in warrior
Has anyone installed a DP clutches clutch kit in their warrior? I am going riding tomorrow and need to get this thing together. With the kit there is one friction plate that is narrow for the cushion spring but there is two cushion springs with the stock setup. should I eliminate one of the cushion springs and if so what position should i put the one with the spring, or is something wrong with the kit? Thanks for any help you can give me.
Old Nov 16, 2003 | 10:04 AM
warriorgod's Avatar
I had the same problem when i istalled my ebc kit on my warrior and i just installed those cushin plates the same way they went in with the stock clucth plates. You can just put it back together as if it was stock.
Old Nov 16, 2003 | 10:06 AM
warriorgod's Avatar
Hey Crotts, where did you get that oil cooler and how much?
Old Nov 16, 2003 | 11:59 AM
Crotts's Avatar
OK thanks, I just left the one spring out, hope it works. I haven't got to try it yet because it was late last night till i got it done. I got my oil cooler from mascman for $60, he is on this forum.
Old Nov 16, 2003 | 12:05 PM
warriorgod's Avatar
How much of a diff. does the oil cooler acually make.
Old Nov 16, 2003 | 12:13 PM
Crotts's Avatar
I haven't really noticed a big difference, but the cooled oil is sent directly to the crank and they are suggested to be used for mod. motors
Old Nov 16, 2003 | 12:53 PM
warriorgod's Avatar
Nice warrior Crotts. did you buy all that or did it come with most of that stuff.
Old Nov 16, 2003 | 06:58 PM
Crotts's Avatar
Thanks, when i bought it everything was stock except the swing arm skid plate.
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
jbrewster94
Sep 23, 2015 04:16 PM
