What is a 6.5-1 compression ratio in PSI??
Old Nov 15, 2003 | 10:30 PM
87Banshee250sx's Avatar
Default What is a 6.5-1 compression ratio in PSI??
-Nick
Old Nov 15, 2003 | 10:36 PM
ThrashAndCrash's Avatar
http://www.geocities.com/terminalvelocitycoaster/adr/
100psi to 119psi .....average of 105psi
Old Nov 15, 2003 | 10:42 PM
Near 105 Psi
sorry......it said the first reply did not go through....Hmmmm
Old Nov 15, 2003 | 10:46 PM
HoundDog06's Avatar
awesome link thrash!
~HoundDog
Old Nov 15, 2003 | 11:13 PM
ScoobyDFW's Avatar
you need to know the cam timing to answer that question and cylinder leakdown. I have an excel spreadsheet that is pretty accurate calculating cranking pressure.
for example:
ENTER CAM SPECS (Rated at 0.006" Lift):
I. Duration = 242
E. Duration = 242
Lobe Center= 105
Advance = 1
CAM TIMING (Calculated):
I. Open 17 BTDC
I. Close 45 ABDC
E. Open 47 BBDC
E. Close 15 ATDC
Overlap 32 degrees
132psi @ 2% leakdown @ 6.5:1
Old Nov 15, 2003 | 11:43 PM
Thanks guys. My banshee "aint got no cam" [img]i/expressions/face-icon-small-wink.gif[/img]. I was just wondering because the manual says stock 6.5-1 compression ratio and it blew a 130 Psi on the gauge. I was just wondering if it was high or low.
Thanks
-Nick
Old Nov 16, 2003 | 01:15 AM
garyc660R's Avatar
Thanks
-Nick
ScoobyDFW finally landed in NY? THats a big jump. Anyway, Scooby is a thumper guy and has probably asumed he would help with some 4 stroke stats....which is cool.
130PSI on a stock Shee at sea level is a little high....but a little high is good..[img]i/expressions/face-icon-small-smile.gif[/img].
Old Nov 16, 2003 | 02:28 AM
LOWBOWTIE's Avatar
My 03 was at 125 psi both cylinders @ sea level after about 3-5hrs on the motor. I checked it when it was new so I know when it was getting low later in life.[img]i/expressions/face-icon-small-wink.gif[/img]
Scooter's Shop
Oct 9, 2015 02:09 PM
Honski250r
Sep 26, 2015 09:40 PM
rockinkgin
Sep 25, 2015 01:52 PM
Ricardo Covarrubias
Sep 17, 2015 08:28 AM
Steeldon
Sep 9, 2015 09:38 AM
