Stage 2 hot came Valve specs different from a stock cam?
Old 12-02-2003 | 08:05 AM
Ugintel's Avatar
Default Stage 2 hot came Valve specs different from a stock cam?
are the specs for gaping the vavles different from a stock cam? if so will the vavle springs and a after market piston also affect the gap specs?
Old 12-02-2003 | 12:09 PM
UBETRUN's Avatar
I use .006 and .008, got to check them often. I tried a "tight" .006 once and the quad acted up once it got hot.
Old 12-02-2003 | 12:43 PM
Ugintel's Avatar
so the tighter they are the faster it will be? what if they are to tight?
Old 12-02-2003 | 04:34 PM
sAyIt_fmf's Avatar
if it is too tight...eventually it will get hard to start.... Very rarely do you see a valve loosen...usually they tighten over time.
slowgsxr97
03-18-2022 04:40 AM
Jordan400ex
04-12-2016 04:59 PM
rawbdiggity
34
09-02-2015 03:16 AM
Huntingdeer
08-23-2015 01:06 AM
Dirtbikemike1
07-11-2015 04:36 PM
Quick Reply: Stage 2 hot came Valve specs different from a stock cam?
