Banshee clutch won't disengage, jammed
Old Dec 3, 2003 | 09:36 PM
AintGroWeddUp's Avatar
Default Banshee clutch won't disengage, jammed
My son's banshee has major trouble, fulcrum that goes in case is jammed into release arm apparently. trying not too spit the case, shaft that presses into pressure plate is lodged, any ideas??
Old Dec 3, 2003 | 09:49 PM
Hozed's Avatar
my buddies jammed up also.. we had to slpit the case and put it back together.. worked fine after.
Old Dec 3, 2003 | 09:52 PM
AACK!! lol, trying to get back too racing, kind of feared that it would have too be split, remember what actual problem was?? Did fulcrum break?
Old Dec 3, 2003 | 09:54 PM
Hozed's Avatar
kinda funny actually.. tranny was jammed.. lever wouldnt move.. could shift at all.. took it apart and it all was fine.. so he just said screw it and put it back together.. hasnt had a problem since.
dont have a clue what it was....
Old Dec 3, 2003 | 10:58 PM
WheelieKing's Avatar
i had the same problem with my banshee. there is a rod and ball asembly that disangages the clutch and and that can heat up and the ball can acctually weld itself to the cylinder it slides in and it causes it to lock up and have no pull at the clutch lever.
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
cdstang
Aug 31, 2015 07:52 AM
