Flywheel puller for Banshee same as the one for the Raptor?
Old Jan 1, 2004 | 11:17 PM
DuneMe's Avatar
Default Flywheel puller for Banshee same as the one for the Raptor?
Is the Banshee flywheel puller the same as the one for the Raptor?
I have a buddy with one for the Banshee and need to help another buddy get his flywheel pulled off his Raptor.
Thanks!
Old Jan 5, 2004 | 02:16 PM
DuneMe's Avatar
Bump!
Someone has to know this!
Old Jan 5, 2004 | 02:19 PM
Hiram's Avatar
They are almost all the same even going cross brands like honda, or suzuki so there's a good chance it will work, just make sure to hand thread it to make sure.
Old Jan 5, 2004 | 02:27 PM
garyc660R's Avatar
The Raptor takes an automotive style puller where the Banshee uses a totally different puller. The center of the Banshee flywheel is threaded inside...the puller screws into these threads too push the flywheel off on the Shee. Be careful the puller lines up perfectly so your bud does not strip the threads on the Rap flywheel. Tell him too tighten the puller up too 75-80 lb ft of pressure and pop the puller a couple of times with a hammer and the flywheel will jump right off there.
Old Jan 5, 2004 | 03:36 PM
PatsRaptor's Avatar
Garys right a raptor takes a harmonic balancer remover to take it of and a banshee/blaster take a small flywheel puller. There only like $20 for the banshee
Old Jan 5, 2004 | 03:41 PM
DuneMe's Avatar
Thanks!
I think the Raptor one is $90 and I know he would prefer to NOT spend that on a tool he will only use once but. . .
If anyone is in the Central Valley / Sacramento, CA area that has one and would be willing to lend it out, please drop me a PM.
Old Jan 5, 2004 | 03:45 PM
PatsRaptor's Avatar
I bought my raptor harmonic puller from Pep Boys for $22 and my Banshee flywheel puller from my dealer for $20
Old Jan 5, 2004 | 03:55 PM
garyc660R's Avatar
Yep, you don't have too have a Raptor specific puller....as long as it accepts 3 bolts and will align correct with the bolts he will be set. The blts are hard too run down since they are a long metric bold thats hardened (says 8.8 on top). Off the top of my head I am thinking the required screws were 8mm X 1.25 thread pitch and 80mm long.
bmxatv10
Oct 14, 2022 06:23 PM
Joe454
Nov 20, 2020 01:19 PM
Scooter's Shop
23
Oct 22, 2015 07:04 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
black_thunder
Sep 22, 2015 07:59 PM
