WARRIOR CARB
Old Jun 26, 2000 | 06:25 PM
OLDWARRHORSE's Avatar
I AM REBUILDING A 1988 WARRIOR: 10.25 PISTON, 390 LIFT CAM WITH SPRINGS, k&N WITH OPEN LID AND A FMF PERFORMAX. DO YOU FOLKS HAVE ANY SUGGESTIONS ON A CARB SIZE AND STYLE, ALSO WHAT DO THINK ABOUT PORTING THE HEAD, IS IT WORTH THE MONEY?
Old Jun 26, 2000 | 07:46 PM
EasterEgg's Avatar
OLDWARRHORSE
Had the same set up on a 92. I used the stock carb with no problems.
My porting was done by a friend who races flat track motorcycles cheap. If you can afford it you should do it any breathing mods to 2 valve head are good. If not at least match & polish the carb to the intake & intake to the head you can do this easily enough yourself.
When you are done be careful you can now over-rev the engine (ther is no rev-limiter) and float the valves. One of them will then hit the piston learned this the hard way.
98 SC 500
Reactant
Mar 30, 2022 02:08 AM
GregM
Mar 6, 2018 06:53 AM
GregM
Jul 29, 2015 09:41 PM
Aitch
Jul 21, 2015 09:40 PM
Reactant
Jul 16, 2015 10:29 PM
