squeeking noise....
Old Jan 12, 2004 | 08:43 PM
Stillander's Avatar
Default squeeking noise....
theres a squeeking noise coming from the back of my warrior, could there be something wrong with the rear breaks or chain?
Old Jan 12, 2004 | 08:55 PM
hondaracer305's Avatar
Most likely, you have something between your pad and rotor if you went through the mud, i would just spray it in the pad, and see if it gets it. gl
Old Jan 12, 2004 | 08:57 PM
Punker660's Avatar
You're rotor's bent. I know because mine is too and it does the same thing. If you WD-40 your brakes, you will have to waste half your pads to get it off. Don't do that.
Old Jan 12, 2004 | 09:03 PM
warrior68man's Avatar
Mine was a few days ago...no brake pads left...metal on metal...
Old Jan 12, 2004 | 09:07 PM
as far as i know, wd40 hasnt harmed my brakes, but ill take your word for it and not do it again, sorry for the misleading info, ill edit that.
Old Jan 12, 2004 | 09:27 PM
Stillander's Avatar
Well i hope my rotors not bent, considering i just got my warrior 3 weeks ago brand new, and i havnt done any serious riding on it, just casual in a field, ill be sure to check it tomorrow to see if it is
Old Jan 12, 2004 | 09:41 PM
Punker660's Avatar
If it's brand new it may just need to be ridden a little more to wear off some of the meat. If it's not bent try riding it more first before you go spending money. Jack the rear end up and run it, watch the rotor for warping. that's the easiest way to tell. If it's squeaking from being new, ride faster to drown out the noise. [img]i/expressions/face-icon-small-smile.gif[/img]
Old Jan 12, 2004 | 10:29 PM
Stillander's Avatar
alright thx for the input punker
ThaChad
Oct 7, 2004 02:18 PM
chrispapy
Apr 14, 2004 11:15 PM
mde8639
Mar 23, 2004 03:42 PM
Elbongo
Nov 4, 2003 09:38 PM
soupcan
May 4, 2002 09:01 PM
