would someone tell me how to push start my blaster?
Old Jan 15, 2004 | 07:23 PM
noremorse's Avatar
Default would someone tell me how to push start my blaster?
the kick start is broken and i want to push start it. can anyone give me detailed instruction on how to do it? i understand ill need a friend (or multiple friends) to help push, and ive seen this done before, but didnt see exactly how. thanks
Old Jan 15, 2004 | 07:29 PM
Dfitz's Avatar
Make sure it is in the run position. Put it in 4th gear, hold the clutch in and then you need to get moving as fast as you can let the clutch out if the tires just drag and don't turn put it up a gear and try again. It is best to be going down hill or have someone pull you with there quad or something. Good luck
Old Jan 15, 2004 | 07:30 PM
sAyIt_fmf's Avatar
IF your on a hill you can do it yourself...if not have someone push you....
Put the bike in 1st gear....get on it....pull the clutch in......start pushing.....when you get a good amount of speed.......let the clutch out and put some weight on the back of the bike....this will help the tires from locking up...if you have traction and speed...it should start right up.
Old Jan 15, 2004 | 07:31 PM
sAyIt_fmf's Avatar
ok someone types faster than me....they choose to use fourth gear cause the engine will turn over a bit easier under load.
Old Jan 15, 2004 | 07:32 PM
TheQuadSport230's Avatar
I'm able to do it alone on my four stroke so you're going to be able alone. Put it into 4th or 5th gear. Hold in the clutch, push the quad with your belly (Can be painful for the ***** when you're not placed correctly [img]i/expressions/face-icon-small-blush.gif[/img] [img]i/expressions/face-icon-small-wink.gif[/img] ) and when you're fast enough, release the clutch and try not making it die if it try to start by giving it some gas. Everybody was looking at me when I was doing it and they were saying WTF?
If you're two person, it's a piece of cake, have somebody push behind you, run aside the quad, just jump on it while the other guy is still pushing and release the clutch. I think you can only sit on it while the other push you
Anyway, let me know if it works for you
Old Jan 15, 2004 | 07:33 PM
Damn I wrote all that message to help you and when I post, 2 persons already replied [img]i/expressions/face-icon-small-wink.gif[/img]
Old Jan 15, 2004 | 07:42 PM
noremorse's Avatar
but when i get started, wont it bieng in 4th gear be too much for it to go and stall? or should i kick it back all the way down to first when it starts? sorry im really really new to atvs with manual trannys. i do have a hill that might work.
{edit} i mean after realesing the clutch, lets say it starts, if i pull the clutch back in will it idle? then put it in first and go?
Old Jan 15, 2004 | 07:44 PM
Dfitz's Avatar
As soon as it starts you pull the clutch in and keep it running, put it back into 1st and off you go.
Old Jan 15, 2004 | 07:45 PM
That's it, when it's going to run, you pull back in the clutch and put it into a lower gear.
Old Jan 15, 2004 | 07:47 PM
noremorse's Avatar
thanks guys, i can thank you enough for helpin me out so quickly! [img]i/expressions/face-icon-small-smile.gif[/img]
2x_lung
1) Engine problems..
48
May 24, 2023 05:22 AM
Shooterj2003
Jun 21, 2015 09:02 PM
BEEFKING69
Jun 17, 2015 12:38 AM
jayking232003
Jun 9, 2015 02:54 PM
1000gade
May 27, 2015 12:37 PM
