Studs?
Old Jan 25, 2004 | 04:10 PM
Hozed's Avatar
Default Studs?
no studs on ice is very lame.. but if there is some snow on the ice it will be fine.. but we plowed a track on the ice and you need studs to move anywhere.
Old Jan 25, 2004 | 08:17 PM
Warrior453's Avatar
Default Studs?
thanks for everything but i found my solution im gonna buy sheet metal screws that r 3/8 in the back and for my fronts im still not sure
Old Jan 25, 2004 | 08:20 PM
87Banshee250sx's Avatar
Default Studs?
sheet metal screws are horrible. My friend had them on his warrior and it didnt do anything. It probably slid more because it reduced the amount of contact the tire had to the ground.
-Nick
Old Jan 26, 2004 | 06:43 PM
Starky's Avatar
Default Studs?
Sheet metal screws will come right out. You can get away with shorter studs, but get the corsest threads you can find.
Old Jan 26, 2004 | 11:49 PM
  #15
maddog56's Avatar
Default Studs?
Use kold kutters in chen-shing c826 ice race tires. 1/2 inch studs, no more, no less. DO NOT USE SHEET METAL SCREWS. The heads will break off and you will have a helluva time getting all of the threads out.
Old Jan 26, 2004 | 11:51 PM
  #16
maddog56's Avatar
Default Studs?
18" on 8" wheels if you have a z or a warrior. I have a piped raptor and the 18"s are too small, just bought a set of 20"s for next week.
Dabears1983
Jun 16, 2015 12:17 PM
ATV_MAN
Oct 21, 2001 04:08 PM
dirtclog
Jun 12, 2001 06:42 PM
Glen
Nov 23, 2000 07:18 AM
Coach2U
Nov 14, 2000 11:28 AM
