Banshee over heating
Old Jan 22, 2004 | 01:48 AM
Outlawlawndragster's Avatar
Default Banshee over heating
I'm not at all familiar with Banshee's but if it has a thermostat check to make sure it's not stuck open if they stick open the coollant never gets a chance to cool in the radiator when your sitting at idle then when you start riding ram air cools the radiator and drops the temp
Seen this happen alot on cars
Old Jan 22, 2004 | 01:59 AM
trailrider500's Avatar
I don't think it does but i have not tore into this quad much yet.. That will change soon though..lol
Outlaw, I hear ya man been there done that a thousand times with them thermostats[img]i/expressions/face-icon-small-mad.gif[/img]
Old Jan 23, 2004 | 09:50 PM
TheBanMan's Avatar
Trailrider500, I just tore my banshee apart last week for a transmission problem... If it is the water perpeller they are not that had to replace...You have to take the right crank case cover off (I think I already had it off) then 5 screws and and a C clip...should be under a $50 fix...and a couple hours
Hope that helps!
Old Jan 23, 2004 | 11:21 PM
Hiram's Avatar
Sounds like your definitely running lean,especially with the colder weather. Turn the air screws in 1 turn to richen up the idle circuit at the least. You said you did a plug chop and it was fine but I highly dout it since Banshee's jetting is tremendisly affected by change in temperature so check it again, I can almost garuantee you need to go up two main jet sizes.
Jeff Roper
Feb 1, 2022 11:48 AM
Sw00p
Sep 24, 2015 02:50 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Jeff Roper
Sep 21, 2015 02:11 PM
poutlaw525
Sep 9, 2015 03:19 AM
