Trying to build the perfect blaster ?
Well, since money's no problem, get a set of good tires like holeshots xc on aluminum rims and cut your unsprung weight down. Then get a set of a arms to widen your front, and some decent shocks. Try Armadillo arms and works shocks, you can find em on ebay without going broke. Maybe a chassis skid plate too. Then when you decide you need more power since your bike handles better, get the cylinder ported.
one imptortant thing to upgrade is suspension. you can mod the **** outta the motor and you still can't go that fast cuz the baster will be bouncing all over. if money isn't a problem i would get elka. and +2 lonestar a-arms. maybe +2 smingarm. get sum good 20 inch tires, i like razr. and a wider axle. then get into the motor. get a pipe kit from toomey. bore it to 240, port and polish. just keep going. theres so many things you can do.
first a good set of rims and tires... get the PD2 i think is the best trail kit... then get ur carb rifled by him... then you should be set... o yea u might want to look at about a +2 swingarm, some front wheel spacers or extended a-arms.. a +2 or so axle and some shocks... that should improve your ride enough where u can go faster without getting the h3ll jared out of u...
